Old 27th May 2021, 09:24 PM
Gearbox next. As usual, I will flip it over to get to the sump and filter, however normally when I do that the diffs are drained ready for re-sealing. This one though is not leaking and so I'm not touching the output flanges and not draining the diffs. That means that if I flip it over, the gear oil will all leak out of these breather holes:
So, I printed some polyurethane plugs for them which worked very nicely
The ATF is nice and clean
I flipped it over to remove the sump. This bolt was stuck and stripped out. I cut a slot in it with the grinder and then persuaded it loose with a cold chise. There are usually a couple stuck on this side because the holes here go right through and the end of the threads get rusty. I have plenty of spare bolts so not a problem.
Stuck bolt at the top with crusty threads. All the other bolts were nice and clean.
Nice and clean in the sump - no fluff on the magnets. The phone had considerable trouble focusing on the shiny surface.
Evidence of a leak on this corner
Left it overnight to drain. New filter and sump back on tomorrow
ID:	26491   Click image for larger version
ID:	26492   Click image for larger version
ID:	26493   Click image for larger version
ID:	26494   Click image for larger version
ID:	26495   Click image for larger version
ID:	26496   Click image for larger version
ID:	26497   Click image for larger version
