Old 12th June 2021, 06:09 PM
Prefferle Prefferle is offline
Seems you have replaced most items. I wonder if it is the shock part of the strut?
Does it do it in comfort mode too?
Good point! So first drive for the day I don’t notice any knocking. Then after driving along for say about 1/2 hour and onwards knocking is certainly present on rough surfaces only. In both comfort and dynamic modes tested.
I’m thinking the knocking is coming from front only but sounds like on both sides. I’m thinking to replace both struts but would hate to invest that much especially as they work perfectly, and not to cure the problem.
The steering ends are tight and I checked virtually everything I could find except engine mounts and struts. Don’t feel the knocking in the steering.
Really sounds like a strut tower mount see item-6 on attachment would this cause it?
Present cars
Daily driver: BMW e65 730d
Batmobile: 2006 S8, D3, 4E 5.2L V10 BSM with (loud) Miltek SS exhaust, Carbon Fibre trim, Alcantara headlining, soft close and keyless entry.
