View Single Post
Old 6th July 2021, 08:15 AM
Green Goblin's Avatar
Green Goblin Green Goblin is offline
Amazing coincidence considering it’s your old car Goran (hope you’re well btw) - I have the exact same problem! Car turns over but refuses to start, however I have all the transmission lights lit up on the dash. Could this be fuel pump as well? Or F125?
I must admit, I can’t hear the fuel pump when I first turn the key but would failure of that cause all the transmission lights to light up?
FYI - there is loads of power from the batt because I keep a CTEK MXS 7.0 connected when it’s not being driven. Turns over smooth as ice and very fast.
EDITED TO ADD - Oh I noticed your post was 19th June - did you fix your car? Was it the fuel pump?
