New gateway tried
Didn't work. Tried various combos and such, but no joy. Initially it was worse with the screen popping up blank. Got it back to the pop up for 5 secs with the traffic info screen.
Tried VCDS / ODB11 in various combos. No joy.
Checked ALL the fuses (multimeter), even the BIG ones in the boot.
Played with the optical bypass loop on what i could easily get to. No difference. Made a full bypass connector using some spare MOST bits, connecting the Gateway to the Head Unit. No difference.
Ordered up a new £50 head unit from ebay. May pop mine out and read the chip if i encounter Component protection - The reader is like £6 anyway!
https://www.dognmonkey.com/audi/how-...ection-cp.html
My only other slight thing, is the battery and coding??? I know it seems a totally random thing but i DID change the battery a few weeks back, may be co-incidental and it was something with the water from the sunroof (though apart from the MMI buttons, which it should operate without, and the gateway autocode (which obviously saw things were not working), it's the only other thing!
