My dad's A6 had an issue with the radio randomly coming on. it did show as a fault with the MMI in VCDS (can't remember the fault code) but I was advised by the garage it was in to stick some WD40 down there. I let the car go to sleep and then sprayed some of the WD40 contact cleaner and it has never done it again.
Not the same problems you guys have had but worth a try if there is any liquid that has gone down there or maybe a dirty contact?
As for CP, I think some people may be able to do it remotely but not too sure
