Old 10th August 2021, 11:05 AM
Conquistador's Avatar
Yes, good point about the boot motor -- most become weak over time to the point of struggling to lift the boot lid up even when the engine is running, then it just gives up and slams shut. Easily rectified with a replacement boot motor which makes the lift good and strong even when just on the battery.
Most boot lids seem to be misaligned, it's a bit of a faff to adjust but they can be fixed. The worst thing you can do with the opening boot is lift it open manually when it's already doing its thing and rising by itself.
Whilst imagining myself looking in the D3's boot, factory rear seat entertainment (RSE) system was an expensive option, and the DVD changer is located behind the left panel in the boot.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
