Old 20th August 2021, 01:30 PM
If the tank is below 1/2 then I always add a gallon or so to fill the pump housing as a precaution since the last thing you want is to dry-start a brand new pump. The filler neck is positioned so that it mostly fills the pump housing first. Much over 1/2 a tank and the housing is submerged anyway.
