Immobiliser is built into the instrument panel which apparently is not working correctly so engine cuts out. Check the fuses and connections( short/open) to the instrument cluster. Disconnect battery for a while ( at least 15 min I would say) and see if that makes a difference after reconnecting. If the instrument cluster has gone bad You will need to replace it and have the immobiliser recoded which only few places can do apart from dealers. If You get a second hand instrument cluster with original key You can use Your key blade on that key and will only need to pair ECU with immo which is pretty simple and DIY if You have diagnostics cable.
