Old 23rd August 2021, 08:18 PM
As usual the fuel line clamps have rusted away so these will be replaced
Original fuel filter?
The fuel line rubbers will be soaked overnight in Bilt Hamber Korrosol to remove the embedded rust
Purple gloop
I put something back in!
The connector for the servotronic solenoid is easily accessible, despite Audi's assertion that they used the ridiculously fragile trailing cable to make it possible to install the rack.
Connector harness attached
I run the cable over the top of the rack out of the way, rather than underneath like the factory did where it could get cooked by the exhaust
This plastic nut used to go on the stud which is now replaced by an M6 rivnut, so I screwed some M6 threaded bar in to it to make a hybrid bolt
Works perfectly
ID:	27046   Click image for larger version
ID:	27047   Click image for larger version
ID:	27048   Click image for larger version
ID:	27049   Click image for larger version
ID:	27050   Click image for larger version
ID:	27051   Click image for larger version
ID:	27052   Click image for larger version
ID:	27053   Click image for larger version
ID:	27054   Click image for larger version
