  #100
Old 12th September 2021, 09:35 PM
Replacement starter cable compared to the original
Once the starter was back on I filled the engine with oil and spun it over with the magic box until it got oil pressure
One of these is not like the others The short coil is the right part number but from a different batch to the others so it has been replaced at some point, but had the wrong spark plug connector attached to it. Surprisingly the engine seemed to run fine, even though this coil wasn't touching the plug
Luckily I have a box of spare coil packs so replaced the short one with the correct part
Spark plugs and coil packs back in.
ID:	27211   Click image for larger version
ID:	27212   Click image for larger version
ID:	27213   Click image for larger version
ID:	27214   Click image for larger version
