Thread: Swapping seats
Old 31st October 2021, 11:18 AM
1996 was pre wired. 1997 they started making specific looms per car.
So early PF car, you can easily fit heated seats as all the connectors were there.
Later, PF car, you will need to install the wiring to handle it.
To find out, pop off the blanks on the dash where the heated seat switches should be. If there are connector blocks behind there, you're in luck. If not, you're not.
