Old 4th January 2022, 04:22 PM
chewy chewy is offline
My mmi screen is currently stuck half way, it started grinding a while back and was able to help it up prior to it being stuck.
I've sourced the brass parts and found a video showing how to remove trims to get mmi unit out.
The video on this thread can not be viewed and showing as private. Does it show how to change the gears? Anyone able to share the video if it does? Will i be able to remove the screen out with it being stuck in the half position?
Thanks in advance.
