Have a read through this thread as I am having a similar problem. Its not coils as I swap them over and the fault stays with cylinder 6. It's not plugs for the same reason.
I get a scan readout saying number 6 injector is have intermittent electrical problems. Next diagnostic is the swap injectors around and see if the fault moves.
Do you have VCDS? I am surprised by the number of failed CPs you have had.
