Old 30th December 2010, 01:56 PM
You should get diagnostics cable, Chinese cables are very cheap on e-bay and they will do all the basic stuff You need with the shareware of Vag-com, VCDS-lite or VWTool then you can check fault codes yourself. Without fault codes it is really hard to say anything as it can be a lot of things.
