Old 17th February 2022, 01:36 PM
Their life is short enough as it is without adding poly in to the mix. I'm not sure it would gain anything in handling, since there isn't much movement in the rubber anyway, and poly under that much movement wouldn't last very long. They are used on loads of things so I think it is still best to use good quality rubber versions.
There used to be a balljointed version but that superceded to the rubber one because it lasted even less time, and was a complete pain to change.
I think the offset may explain why some cars just eat through them and some don't, but its very hard to tell when they are on the car, especially with it jacked up.
