Thread: Manual swap a8L
View Single Post
Old 21st February 2022, 07:40 PM
Fredde Fredde is offline
Hey sorry for all the questions but a standard a8 40v with the s8 intake manifold, TB, injectors, and MAF would that work well with the s8 map? Afaik the s8 also has different cams and exhaust manifolds would those not be needed to make the s8 map work? Been reading up on the whole manual ecu tune thing and using the s8 parts and tune is starting to sound like the simpler option. Another thing is a manual swapped car is not actually supposed to be able to pass Swedish MOT so I may actually end up being forced to do a engine swap as well to register the car as a “modified vehicle” but if that is the case I will be building myself an d2 S8L altho finding a 40v s8 engine for a price less than I bought the car for doesn’t look to easy.
Are you sure its a 6-speed? According to the data and my experience the B5 1.9 TDI is a 5-speed 01A. The 01E only came with the 2.5TDI in the B5. It wasn't paired with a 1.9 until the C5 and B6 with the PD130. Also the B5 diff is different to the D2. The ideal donor is the A6 C5 2.5TDI, or possibly a B6 1.9TDI although they have odd output flanges.
I've done a swap in an S8 with a TDI 01E and its ok, not great. 6th is just a bit too high, meaning it does about 1600rpm on the motorway and while that is great for fuel consumption, having to change down to accelerate gets tedious.
You would have to have your propshaft extended since there is no LWB manual from the factory. In theory you could bolt the front of a manual shaft on to the back of a LWB shaft, but manual shafts are extremely rare. Easier to extend it if you can find someone capable of doing it.
S4 stuff does work, but you'll need the spacer between engine and gearbox which will also impact the propshaft. TTV Racing in the UK make a flywheel to take a B5 RS4 clutch which doesn't need the spacer - that's what I've used in the past, and the RS4 clutch is quite cheap. Get the heavy flywheel if you go this route.
The only other thing to bear in mind is that you'll need an S8 manual map in the ECU since there is no manual map for the A8 4.2. This means also swapping to the S8 inlet manifold and throttle body, injectors, and airflow meter so the ECU knows what is going on.
D2 A8L 4.2 AQF 4.2 LZ9W Ebony Black Pearl Fully electric rear seats D3 s8 front brakes s8 mirror housings 18x8 Avus 3 winter wheels PDC rear blinds Nav Electric steering wheel adjustment TPMS Leather pack 1 with retrofitted stitched leather lower dash panels folding auto dimming mirrors solar sunroof cold weather package CD changer double glazing all around memory seats passenger seat adjustment from rear seat Bose servotronic xenon plus headlights
C5 Allroad 4.2 BAS 4.2 LZ6G Irish Green Metallic Bose RNS-E Rear Blinds folding auto dimming mirrors Heated MFSW with shift buttons PDC Recaros heated seats all around CD changer Nav
B5 A4 STCC Edition AJL 1.8T Quattro Built engine GT28RS maxxecu Remote locking Trip computer Sport seats Eibach/Bilstein suspension Flexfuel
D4 A8 4.2 TDI
Previous Audis B7 S4 Avant B5 A4 Avant 1.8T B8 A5 SB 3.0tdi C5 A6 1.8T C5 Allroad 2.5 TDI
