View Single Post
Old 6th March 2022, 10:51 AM
Next job - find out why the ECU won't communicate with VCDS. No continuity between the body harness and ecu connector...
I am having the said same issue with my VCDS Lite. Actually with my cheapo reader as well. The cheapo says linking error, VCDS unable to connect. Did you go direct to the ECU or are there prior items to check? I have checked the terminals at the OBD2 port and all seems good, used a breakout box and the resistance between terminals also seems to check out.
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
