Originally Posted by projektzwo
I managed to find a nice set of sport seats but from facelift D2, anyone (@IT) know if the connectors are the same on both pre-facelift and facelift models?
The basic power / memory / heat is the same. Later cars had airbags and rear passenger footwell lighting, but they come on extra pins and connectors from memory so FL seats into a PF should work ok.
Note that FL leathers are different colours and textures to PF. Black PF is darker than Black FL etc. You will need to change the armrests to match as it will be obvious, and door cards might show it too depending on the trim of your car.
The tricky bit, is that the rear FL seats differ quite a bit as they are designed for a 3 point middle seatbelt, not a lap belt, so they might not swap in so nicely, and if you have PF rears and FL fronts the colour match will be awful imo.
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
