Thread: Misfire ???
Old 5th May 2022, 11:48 AM
ulfilias ulfilias is offline
Originally Posted by Prefferle View Post
Hi Lee well it’s going to be fuel, spark or compression. Not sure what engine you have but for me with a similar issue turned out to be a vacuum leak caused by defective the oil separator valve, but that was on a BSM Engine. You may want to check all your vacuum lines and breather as another possibility. Cheers
Bit of an OLD thread here. Fixed some years back. Was an issue with the "coolant" lines, a bit of a BODGE job by the MEH installer, which are used to by the vaporiser to convert the LPG liquid into a gas, as such it was like the system was starved by fuel causing the misfires
Everything appeared fine, apart from the engine codes, it was getting fuel, but not in the right form to spark properly!
Current :
Previous :
Also :
