Old 29th May 2022, 03:59 PM
Prefferle Prefferle is offline
I've read multiple posts from people having this same knocking issue and they seem to have replaced everything to no avail. Two specific things that are mentioned are the ARB bushes and the 42mm inside the front strut.
You mention about replacing the stabiliser bar so that would rule that one out. That leaves the strut itself. The nut in question is under the grommet marked as #4 in the attached image, with the comments being that it may have worked loose. Having replaced everything else, it's worth investigating.
Thanks Steamship, I thought as much initially and sent back the new strut on warranty and they replaced it free of charge, same noise. So with my original old strut, then with the new strut then with another new strut same side same noise.. frustrating to say the least… cheers,
Present cars
Daily driver: BMW e65 730d
Batmobile: 2006 S8, D3, 4E 5.2L V10 BSM with (loud) Miltek SS exhaust, Carbon Fibre trim, Alcantara headlining, soft close and keyless entry.
