Old 30th May 2022, 10:18 PM
Prefferle Prefferle is offline
We're running out of things to check. Looking at an image of the suspension, you seem to have worked on almost every single nut and bolt. Grasping at straws here, but any likelihood that the bolt (#2 in the attached image) could be loose?
Hey a great point - I’ll be checking that bolt next. What I was thinking was that the axle may be worn and causing that noise. There is no clicking when cornering though which is one sign of a worn axle cv joint… it’s certainly one of the few last possibilities…
Present cars
Daily driver: BMW e65 730d
Batmobile: 2006 S8, D3, 4E 5.2L V10 BSM with (loud) Miltek SS exhaust, Carbon Fibre trim, Alcantara headlining, soft close and keyless entry.
