The big black connector, from memory, has few wires in it. I seem to recall it has a gala/wheel pulse input (from abs) and reverse line signal (so the car knows if the pulse is going forwards or backwards).
There was a second 'gala' input on the 8 way power block, which was also a speed input.
One was used for the GPS positioning, and one was used only for telling the unit you were moving, and to turn the TV off if in motion. A common hack was to put that on a switch so tv in motion would work. Sat nav was unaffected.
Likewise, losing a reverse signal isn't the end of the world, unless you spend a lot of time driving backwards underground, but I also suspect that signal would be mirrored over canbus which the RNS-E would likely read natively from the cluster.
So, yes, i dont doubt that black connector is happily surplus.
On the Cd changer, vw/seat/skoda/RNS-E Audi all used a square connector for the CD changer. When I did my retrofit, I swapped the CD changer cable for one of those and it plugged straight in.
I guess, with the RNE-E having SD cards, the need to CD is somewhat reduced so not something people worry about plugging in.
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
