Old 17th October 2022, 12:15 PM
dangerdred dangerdred is offline
Strange, so I charged my battery and it was 12.8V after letting it sitting disconnected from the charger overnight, but when I connected it back up to the car I had two bars on the MMI!!. I cleared all DTCs and did a scan and got...
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4E0 910 402 E HW: 4E0 907 401 D
Component: 3.0L V6TDI G000AG 0020
Revision: --H05--- Serial number: AUX3Z0H1342405
Coding: 0011973
Shop #: WSC 02313 785 00200
VCID: 1E65DD6D3CB162BBF5F-804A
VINID: 9D196AAAA115188780042000249DC8F77E
1 Fault Found:
005715 - Please check DTC Memory of ABS Controller
P1653 - 002 -
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 237246 km
Time Indication: 0
Date: 2022.10.14
Time: 22:29:34
Freeze Frame:
RPM: 945 /min
Torque: 132.6 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.25 V
Bin. Bits: 00101011
Torque: 284.7 Nm
Readiness: 1 2 0 0 0
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 J HW: 4E0 614 517 BQ
Component: ESP 5.7 allrad H49 0540
Coding: 0008357
Shop #: WSC 02313 000 00000
VCID: 2A0D01BD70F99E1B997-807E
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Address 09: Cent. Elect. Labels: 4E0-910-279.clb
Part No SW: 4E0 910 279 S HW: 4E0 907 279 S
Component: ILM Fahrer H16 0240
Coding: 0143122
VCID: 38292BF5BE553C8B1F3-806C
Subsystem 1 - Part No: 4E2 910 113 C
Component: Wischer WWS D3 H60 0440
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0002
Coding: 00139548
Shop #: WSC 02313
1 Fault Found:
00908 - Control Module for Wiper Motor
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 2
Reset counter: 182
Mileage: 0 km
Time Indication: 0
----------------------------------------------------------------------Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000002093
VCID: 2019E39506C5544BC73-8074
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 2802010529
Coding: 344530393135313035412056413032383032303130353239
Shop #: WSC 11111 111 45725
1 Fault Found:
00992 - Consumption Cut-Off Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 237246 km
Time Indication: 0
Date: 2022.10.15
Time: 00:09:58
Phantom Black 2008 A8 3.0 TDI SE ASB
