Picking up from where Frankie ran out of steam, this rescue mission has taken a lot more time (and money) than hoped, but I promised to save it, and I'm glad to report she is running well again. Very well in fact.
The initial Big issues:
- No MOT
- Very rough idle / hard to keep running
- Oil leaks
Work done:
- Replaced bonnet cable as it snapped on day 1. What a joy of a job that was breaking in.
- Replaced oil separator as it was split, sucking in air and coating everything with oil inside and outside the engine.
- Smoke test - revealed a 50p piece size bung in the front of offside head was completely missing, sucking in more air, and spitting out more oil. Scratching my head as when/how that went missing - Replaced
- Replaced all 10 spark plugs $
- Replaced all 10 coil packs. $$
- Replaced all 10 injectors $$$
- Replaced the failing water pump, aux belt and pulleys
- 2 new MAFs
- Carbon clean
- Manifold clean
- All new gaskets for above
- Oil + filter change
- PAS fluid change
- Brake fluid change
- A/C regas
- Air filters
- Fuel filter
- Replaced bluetooth module as existing one was dead
- Replaced a failed parking sensor
- Unblocked sunroof drains as all 4 were blocked solid
One of the biggest issues with this car was the 'manifold flap delete'. I understand why people do it, but 'coding out the flaps' it would seem basically equates to 'turn off all the error logging on the ECU' which makes troubleshooting issues an absolute nightmare.
The hardest thing to troubleshoot is misfires, when you have 10 cylinders to go at, and no misfire counters to work with, hence why we ended up just swapping everything.
On the plus side though, its a bit easier to get an MOT as the engine warning light will never, ever come on no matter how badly it is running !
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
