Thread: VCDS Fault code
View Single Post
Old 22nd December 2022, 12:53 PM
This code usually happens because the brittle plastic pipe connecting the solenoid valve on top of the bank 2 fuel rail to the two SAI vacuum valves has perished and broken and so they aren't actuating on a cold start. The ECU can see they're not working by the readings from the secondary O2 sensors.
Its simple enough to fix by replacing the broken plastic pipe with standard 4mm braided vacuum hose and a T piece.
Well, she's spot on yet again (see photo below). And thanks to Sean as well for sending me the guide from Audipages.com. I only replaced the plastic pipes that Michaela mentioned as I couldn't get to the vacuum reservoirs without major (for me) dismantling work.
Started it up and the engine management light went away without even needing to clear it!
