Old 22nd January 2023, 07:00 PM
That much condensation suggests excessive moisture inside from one or more of the usual sources. Check all the drains and carpets, and ideally put a dehumidifier inside for a few days.
Is it laid up or in daily use? If its in use make sure the AC is always on as it helps with the general moisture buildup.
