Old 25th January 2023, 07:15 PM
Oh, make sure to order new Oetiker clamps for the PS lines 2x N10255501 as worm-drive clamps don't work for some reason - they always leak.
Also new o-rings for the trans cooler lines 2x N90666001 as they will be pretty crusty and squished. Make sure to thoroughly clean the cooler line sockets on the rad with scotchbrite or similar and lube the o-rings with ATF so they don't get pinched when going back in.
I keep both in stock if you don't have easy access to TPS or a dealership parts counter
