Old 30th January 2023, 05:41 PM
danyalmakda danyalmakda is offline
Using VCDS you can check whether the cruise control switches are operating, if corroded the signal can be intermittent or need firmer/repetitive pressure.
Some people have also recommended squirting contact cleaner into the stalk and then exercising all the switches vigorously.
Mine didn't work at all when I got the car, but repeated "exercise" has made them fairly reliable.
PS Which area of Leicester? I'm from there originally and still have relatives in various districts.
Will keep applying the buttons and hopefully get it sorted
I’m from Oadby
2002 Audi A8 D2 3.7 Quattro AquaBlue
