Old 6th February 2023, 09:50 AM
Check posts #9 and #10 in the following thread. The thread is about the D3 but post #9 references the D2 and includes photos. Use a multimeter to check resistance on the two sensors. Post #10 mentions a contact cleaner for the airbag connector block:
Thanks for the link Steamship. Not so sure about the resistor fix but will give a few squirts with contact cleaner (assuming WD40 Contact Cleaner is a viable option) to see what happens. As the fault appeared to be intermittent it may be a good fix. Age and dry joints
Quick glance at the wiring diagram seems to confirm left is odd, right is even.
Something for the weekend..........
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
