Old 4th March 2023, 06:56 PM
donp38 donp38 is offline
Hi All.
So checked with VCDS that all was 'switched on'.
Then watched as I used the switch on stalk.
All good.
However, when you watch closely, there was a 0000 signal between the switching. This could cause the CC to deactivate?
Sprayed contact cleaner in the stalk switch at the same time as switching and pressing all functions...
back to VCDS and did the same switching....hey..well you would not believe....now clean switching with no 0000 signal in between switching.
Road test next...all well..working perfectly.
Many thanks to all.
Cheers.
