Thread: My 01 S8
  #49
Old 6th March 2023, 09:53 PM
Audifan Audifan is offline
The link I provided in my last post (which is missing some important items which I will highlight here), doesn't state anything about this bracket for the front door cards.
Sorry that this isn't the best picture but the above picture of the bracket is
for holding a wiring harness.
After you get the lower door handle cover off, there is two little screws (already removed in this picture)
that need to be removed and then there are two 8 mm bolts that needs to be removed.
Once you remove the door card, you can pry up this large air tube so you can get the wires removed.
I haven't figured out how to remove the round push pin without damaging it.
This picture is from the front oxblood door card where the push pin is broken that holds the large air tube seen in the picture above.
These retaining clips (with the red dot) needs to be removed in order to remove the wires.
This memory seat switch needs to be removed.
Then you need to remove the wire plug in order to push the wire through.
This is the oxblood front door card with the wire plug removed.
ID:	29343   Click image for larger version
ID:	29344   Click image for larger version
ID:	29345   Click image for larger version
ID:	29346   Click image for larger version
ID:	29347   Click image for larger version
ID:	29349   Click image for larger version
ID:	29350   Click image for larger version
ID:	29351   Click image for larger version
