Old 7th March 2023, 08:39 PM
Audifan Audifan is offline
Is it my eyes, or has someone pushed new pins into the new connector block without wires attached?
I'm not sure what it is. In this picture, you can see where the wires go in are empty.
Do the wires even need removing? Just put the existing connector in the new shell.
I really don't know. If you think just reusing that existing connector is safe enough to use for the new shell, I'll just put on the new shell.
Indeed it is. Something got me thinking about that connector in your other thread and your new photo nailed it for me. The entire pig tail has been replaced at some point with two core electrical wire. That might also explain the state of the connections to the pins. On the two airbag connectors on the rear seat, one side has brown and yellow wires (on your other thread where you compare connectors) and the other side (the broken connector) should be brown and white.
Here is a picture of the other side connector. I think the reason for the different color wire is because the oxblood back-rest is from a 2003 car and my car is a 2001.
ID:	29372   Click image for larger version
