18th March 2023, 06:36 PM
Originally Posted by steamship
Found similar posts elsewhere and two stood out that you might already have seen. You've checked the wiring at the connector end and the connector itself, but I saw these the following comments that are worth investigating, both being broken wires:
I was able to fix my issue with N111, wire was pinched in the wheel well.
1st time I removed the sheild and the compressor as mine was broken way up where it goes into the main loom.
Also worth doing a resistance check as mentioned in this post:
https://forums.ross-tech.com/index.p...71/post-256551
Cheers Sean 🍻
