Thanks all, for your kind words and helpful information.
I've got the oil pressure switch on order, so hopefully that'll solve the recurring warning.
The electrical fault on the gearbox is probably the wiring to the selector switch itself, as I already identified a broken wire there, so perhaps some damage has occured as it has been moved around.
The CD changer has always been quite unreliable, so I really need to look at alternatives to try and get a iPhone interface. The Dension offerings look quite pricey unless I can luck out with a used one.
Any other suggestions?
Thanks again
Brian
2000 Audi S8 D2 4.2 V8 FL
1997 TVR Cerbera 4.2 V8
1992 Peugeot 205 Gti 1.9
