Old 25th May 2023, 07:45 AM
Ronin Ronin is offline
It over-reads by 2psi, ish.
Would you rather have it over read by 2psi and show temperatures or.... strip the whole interior and wheel arches out to install the ancient oem audi tpms system that doesn't even display the pressures or temperatures and at some point will die due to water ingress?
At least the android TPMS system is installed in the center console, so you will spot the leak way before water level reaches that high
