Next step then is to loosen the hub bolt on the suspect corner and see if the bearing is noisy once its no longer constrained by the bolt. I had the same problem on Lucy's TT a while back - a horrible howling on the left but with the car intact I couldn't feel or hear anything. As soon as I loosened the bearing it was obvious.
Do you mean the big uber bolt on the driveshaft?
