Thread: ABS Fault !!!!!
Old 25th September 2023, 09:54 PM
donp38 donp38 is offline
Great.
So. I suspect some recent work has been done on the breaks before my ownership.
The sequence I used to bled is not as MJ has suggested so will do in two stages.
step 1 : Bleed sequence as per MJ.
Test
If not fixed then.
Step 2 : VCDS sequence..
However....I assume VCDS will tell me what to do and when?
Many thanks..
