Old 4th October 2023, 09:24 AM
Originally Posted by Mossyboy1978 View Post
Is it possible that this is something to do with the coolant temp sensor at the back of the engine?
Could well be, I've certainly had problems with them and replaced more than one.
Important to remember that the sensor has two separate parts to it, one feeds the dash display, the other the ECUs. So it can (and will) show a normal temperature as well as cause problems.
Tip: If you do replace it buy the o-ring seal and retaining clip as well!
