So the final scan (clean sections omitted) was:
Thursday,05,October,2023,11:54:15:38881
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.3.1.0 (x64)
Data version: 20230421 DS346.2
www.Ross-Tech.com
Scan: 01 02 03 08 15 17 35 37 45 55 56 76
VIN: WAUZZZ4D63N001043
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 4D0 907 389 E
Component: ABS/ESP allrad D57
Coding: 08397
Shop #: WSC 02313
VCID: 316F2301FBBEBB1B74-5178
1 Fault Found:
01119 - Gear Recognition Signal
35-10 - - - Intermittent
Address 35: Centr. Locks Labels:. 8D0-862-257.clb
Part No: 8L0 862 257 P
Component: CV-Pump, Alarm, RC D17
Coding: 16235
Shop #: WSC 02314
VCID: 428D7CCD4E1830839D-4F02
1 Fault Found:
01134 - Alarm Horn (H12)
49-00 - No Communications
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D07
Coding: 00001
Shop #: WSC 00000
VCID: 0401BAD5148CFEB3EF-4B4A
1 Fault Found:
00776 - Level Control System Sensor; Left Front (G78)
28-10 - Short to Plus - Intermittent
End-------------------------(Elapsed Time: 02:14)--------------------------
And the first scan had the following additional errors:
Address 01: Engine Labels: 4D0-907-560-AVP.lbl
Part No: 4D0 907 559 AA
Component: 4.2L V8/5V G 0002
Coding: 10753
Shop #: WSC 02629
VCID: 6DD7FF7127061FFB10-5178
WAUZZZ4D63N001043 AUZ7Z0A2019960
6 Faults Found:
16804 - Catalyst System; Bank 1
P0420 - 35-00 - Efficiency Below Threshold
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
16814 - Catalyst System; Bank 2
P0430 - 35-00 - Efficiency Below Threshold
17819 - Secondary Air Injection System; Bank 2
P1411 - 35-10 - Insufficient Flow - Intermittent
17831 - Secondary Air Injection System; Bank 1
P1423 - 35-10 - Insufficient Flow - Intermittent
17521 - Oxygen (Lambda) Sensor; B1 S1
P1113 - 35-10 - Internal Resistance too High - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No: 4D0 927 156 EC
Component: AG5 01L 4.2l5V RdW 1010
Coding: 00111
Shop #: WSC 02314
VCID: 6ED5F87D2A00E4E329-5178
3 Faults Found:
17090 - Transmission Range Sensor (F125)
P0706 - 35-10 - Implausible Signal - Intermittent
17147 - Shift Solenoid 3 (N90)
P0763 - 35-10 - Circuit Failure - Intermittent
17142 - Shift Solenoid 2 (N89)
P0758 - 35-10 - Circuit Failure - Intermittent
Coding: 08397
Shop #: WSC 02313
2 Faults Found:
01203 - Electrical Connection between ABS and Instrument Cluster
31-10 - Open or Short to Ground - Intermittent
Address 08: Auto HVAC Labels: 4D0-820-043-MYX.lbl
Part No: 4D0 820 043 Q
Component: A8-Klimavollautomat D13
Coding: 00081
Shop #: WSC 02314
VCID: 2A5D346DD668C8C3B5-2592
1 Fault Found:
00734 - Potentiometer in Central Vent (G142)
30-10 - Open or Short to Plus - Intermittent
Coding: 16235
Shop #: WSC 02314
9 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
76-00 - Terminal 30 missing
77-00 - Internal Supply Voltage
Address 37: Navigation Labels: 4B0-035-192-RNSD-37.lbl
Part No: 4D0 035 192 M
Component: RNS 4.2 H06 BNO 0102
VCID: 295FCB61D36EC3DBBC-4B18
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
44-00 - Short Circuit
Address 45: Inter. Monitor Labels: 4B0-951-178.lbl
Part No: 4D0 951 177 B
Component: Innenraumueberw. D06
Coding: 00001
Shop #: WSC 00000
VCID: 2859CE65C864FAD3A3-5178
1 Fault Found:
01462 - Anti-theft alarm ultra sonic Sensor (G209)
53-10 - Supply Voltage Too Low - Intermittent
Coding: 00001
Shop #: WSC 00000
2 Faults Found:
00774 - Level Control System Sensor; Rear Left (G76)
28-00 - Short to Plus
The central vent potentiometer issue I've had myself and fixed by moving the dial back and forth a few times. I did that to this one too.
2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation".
(Even rarer than a D2 S8!) Oh, and a brand new engine at just under 30,000 miles on the factory one!
e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course.
(internal dimming mirror added later)
