Old 8th October 2023, 08:46 AM
donp38 donp38 is offline
Converter clutch then. Either the friction material is worn out or the piston seal has failed so the clutch isn't locking up properly. JPAT in Bristol can refurbish the converter for about £450 iirc, although obviously getting it out is a bit of an ordeal. It might be, with labour, that its logical to get the gearbox rebuilt while its out.
MJ...
I still have a 'supercharger' noise sometimes when acceleration as the vehicle changes gear.
So what is labour time to change gearbox and torque converter?
Just thinking if I could figure out the part numbers are they still available form Audi Tradition in Germany?
