It comes out really easy just a few screws if I remember right. Mine was attached to a frame that also holds the telephone unit. If you are not using this you can remove the whole lot by removing four allen headed bolts screwing it to the boot deck. The cabling all disconnects easy and can be fed down to the space below where the amp is leaving you a nice clear cubby hole.
Interested too to know if it has any value as it is sat in my shed with the head unit (no code) gather dust.
