Old 14th January 2024, 02:08 PM
Resurrecting a very old thread as my MOT is due and washer jets are a bit feeble......
Decided to try descaler first (HG stuff as noted above, neat) but in situ. Weather isn't conducive to dismantling!
First I just applied a few drops with a small brush, observed fizzing so repeated a few times over an hour or so.
Then I used a small syringe, loaded with a couple of ml of descaler, and pumped it gently in and out of each nozzle in turn. It obviously squirted out the other nozzle in each pair, along with fizzy bubbles.
Again repeated a few times until it ceased fizzing and they're now working well. Ideally need a bit of adjustment but are fine for MOT purposes.
As implied above, I think the heated nozzles dry out the nozzles excessively causing them to block.
