Old 4th June 2024, 10:38 AM
I also wondered if it was worth trying the stainless steel polish I use on the tailpipe as I assume that also is a mild abrasive.
The answer to that is no, it just made the surface a bit cloudy but didn't remove any more film.
A further round of Brasso/Silvo got it back to "reasonable" again.
I suspect to really get it perfect you need the full aggressive process as followed here: https://forum.a8parts.co.uk/showpost...58&postcount=1
Of course I had the usual two steps backward before any forward.... the trim strip retaining screw managed to escape my clutches and disappeared into bumper cavity.
I eventually found a suitable but ugly replacement but then decided to hunt for the original. Foglight grille off and I could just see it; scraped knuckles and I just managed to retrieve it!
