Sorry just noticed replies,
So I havent pursued the A/C compressor change yet, its one of the few things i havnt touched however the AC works fine whether the noise is happening or not. For example when i start the car first off, the noise isnt there as it only tends to show when the car is moving at low speed. But i can sit stationary and AC works perfectly.
Re the climate fans possibly touching a casing, it could be that but the noise has a very definate start and stop to it that doesnt fit in my mind with a fan gently nudging up against a case.
Just to reitterate, the times i can hear it is when the car is moving at slow speed. It stops abruptly when i bring the car to a stop every time. (this makes it hard to locate as i cant open bonnet to find when stationary)
It then starts sometimes when i start moving, maybe 5-10mph+ but not always, maybe 25-50% of the time when pulling away.
I cant tell if its happening at high speeds.
Its usually worse when the car is cold but not always.
It happens no matter if i have the A/C on Eco setting.
It happens no matter if i turn the entire climate control on/off.
Its coming from the front left hand side of engine bay from my drivers perspective.
It sounds like a pump that is trying to pump something but the reservoir is dry, that kind of groany grumbling noise you get when a pump isnt pumping liquid anymore.
I will try and get a recording of it...
Thanks
2007 A8 3.0Tdi Quattro Sport
Quartz Grey Metallic LY7G
20" Alloys
Black leather sport interior
Latest 5570 2g high MMI
Front rear park sensors
Reversing camera
HID Bi Xenon with AFSII
Exterior light package
Bluetooth
Bose
DAB
