View Single Post
Old 7th August 2024, 09:24 AM
Fredde Fredde is offline
Do you have access to VCDS? If so, it might be worth trying to disable the electric blind option for the drivers rear door, recycle the ignition, and then re-enable it again, in the hope that the electronics 'reset' the blind position.
I'm saying this based on it being with a garage for three weeks, and maybe during that time the battery was disconnected, or the car was jump started. Some weeks ago, my S8 was sitting idle for weeks outside and it wouldn't start. I got it jump started, but in the process, it played havoc with the MMI, with several functions disappearing completely. One was the visual when changing the temperature. Started it a day or so later and functions were back again. This sounds like the odd behaviour from the blinds.
If you're familiar with VCDS, go into module 72 (Door, Rear Right), and then into Coding, and you'll get the following screen. Make a note of the highlighted number ('0032623' in my case). Subtract 128 from your number, and then click 'Do It!'. After that, exit out of VCDS, re-cycle the ignition, and then go back into VCDS. You'll need to check and clear the Error Codes as you'll have one for the electric blind. Go back into Coding and change the number to the original number.
Hey you don't happened to have this info for the d4? Currently looking to retrofit rear blinds but having trouble finding how to code my door modules.
D2 A8L 4.2 AQF 4.2 LZ9W Ebony Black Pearl Fully electric rear seats D3 s8 front brakes s8 mirror housings 18x8 Avus 3 winter wheels PDC rear blinds Nav Electric steering wheel adjustment TPMS Leather pack 1 with retrofitted stitched leather lower dash panels folding auto dimming mirrors solar sunroof cold weather package CD changer double glazing all around memory seats passenger seat adjustment from rear seat Bose servotronic xenon plus headlights
C5 Allroad 4.2 BAS 4.2 LZ6G Irish Green Metallic Bose RNS-E Rear Blinds folding auto dimming mirrors Heated MFSW with shift buttons PDC Recaros heated seats all around CD changer Nav
B5 A4 STCC Edition AJL 1.8T Quattro Built engine GT28RS maxxecu Remote locking Trip computer Sport seats Eibach/Bilstein suspension Flexfuel
D4 A8 4.2 TDI
Previous Audis B7 S4 Avant B5 A4 Avant 1.8T B8 A5 SB 3.0tdi C5 A6 1.8T C5 Allroad 2.5 TDI
