OK, i have a similar tow bar on my D2. I think the most likely issue is that you’re trying to put it in (excuse unintended innuendoes) with the ‘balls’ out. You need to pull out the knob (I did warn you!) and rotate it until the balls retract into the body of the tow bar and it should lock in that position. Then push the towbar into place and, when in position, the balls should spring out to hold it in to place. Then rotate the key and remove it.
Another issue, if that doesn’t work, is that the inside of the mounting bracket gets cruddy. It’ll need a good clean with something abrasive and plenty of WD40.
2002 Final Edition S8. Ebony black with Silver Grey leather and myrtle wood trim. Current mods: solar sun roof, 20mm rear spacers, 15 mm on front, red brembo callipers, 6k headlights, rear view camera, engine remap, alloy dash dial rings, alloy navi rings, tt/phaeton pedal upgrade, (and custom matching foot rest) dension ipod interface & parrot hands free kit (both fully hidden), av input, tv in motion switched thro' PF switch in blanking plug right of steering column, Audi 'quattro' sill covers, repositioned centre console switches, radio clock, .
