Thanks, Sent him a PM so i'll see,
In the meantime I checked his posts and found one that details a recalibration via VCDS, the measurements we're a bit off on my car, so I went through the whole process.
Same thing, car just lifts and lowers the rear over and over again until the compressor overheats.
Update:
So I have checked and tested each sensor today, all connections are clean, and wires are unbroken, I even tested the movement of each sensor manually whilst watching VCDS and they all seem to report correct readings. I even checked the valve block and other areas for leaks.
I have noticed that the car will sit stable whilst idling and no one is in the car. As soon as I sit down in the car, it starts this cycle of raising and lowering. Any new ideas?
Toby
2007 S8 D3 5.2 V10 - Jap Import in Daytona Grey
2004 BMW X3 2.5i Manual (Old Workhorse)
Previous:
2009 S5 4.2 V8 - Phantom Black with Red leather interior
2006 A4 3.0tdi Manual - Black with Black Leather
2001 BMW 323ci 2.5i Manual
