So an interesting test today. Started all looking normal but after a few hundred yards the D highlight went out.
From then on the car generally started behaving as if in Sport mode - late upshifts, quick downshifts, higher revs etc. Though I did before long flip into "real" S mode which worked as it should with highlights on the S and gear numbers if I used the Tiptronic buttons on the steering wheel.
I pottered around in 30/40mph limits locally and noticed that when I engaged Cruise Control it immediately felt as if it was back in D, not S. That was 100% the case over a few minutes of back streets including some reversing. After a reverse the D symbol illuminated only very briefly and behaviour reverted to S style.
BUT oddly after a little while more, without me doing anything, it changed to normal D behaviour (Only, no highlights in the DIS) and stayed that way for a few miles until I got home.
Handbrake on, foot on brake pedal, didn't touch the shifter! Grabbed VCDS laptop from the glove box and plugged it in - F125 definitely showing. Z3/1111.
So basically at present it's driveable as I can use the Tip buttons to upshift if it's inappropriately stuck in S mode. And if it drops into D without me doing anything that's fine.
Anyone got any thoughts on that?
2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation".  (Even rarer than a D2 S8!) Oh, and a brand new engine at just under 30,000 miles on the factory one!
e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course.  (internal dimming mirror added later)
