Old 21st March 2025, 11:13 AM
You've got a ski hatch, that might help, not sure how though....
If you can get something through the hatch to remove the offside lights cover in the boot lid that definitely exposes some of the mechanism.
Though that's behind the keylock/button so may or may not be the end that's broken/disconnected?
Another thought is that sometimes a latch mechanism is stuck under tension but will release if pressure is removed. In this case pressing down firmly on the boot lid while unlocking.
A bit like wiggling the steering column to allow the ignition key to turn.
