4H0199382CD is correct for the right side. The left side is 4H0199381CD (typo on yours).
The 4G0 codes are for an Audi A6.
399-090 is for the armoured version, but those specific part numbers are the same. 8K0399151CM is fine for the rear. 4H0399151AT is for the left side of the transmission and 4H0399152AT is for the right side. This is the original one for your car, but you can use the 4H0399152BC, as that is the superseded part. With reference to the date, the AT is on cars up to 14/11/2016 and BC after that.
As ainarssems pointed out, you can't get the propshaft mount, but I've seen aftermarket one mentioned.
Reason: My Typo This Time
